See attached image.
Is there a way to scroll the context menu window when it gets cropped like this? I can never see the third row of buttons!
(Actually, this happens in v8.1, as well.)
v9 Cropped context window bug?
- Attachments
- Cropped context window
- context-menu-cropped.png (86.28 KiB) Viewed 13541 times
Re: v9 Cropped context window bug?
No, unfortunately not at the moment.
What is your display resolution? I am guessing something like 1280x700? Note that the recommended display resolution for Titan Mobile is 1280x800.
This is on a Lenovo laptop with native 3200x1800 ("retina") resolution.
Everything else in Titan seems to display just fine, but that particular window always loses its 3rd row.
Interesting. I can only think it's something to do with the high DPI of those screens and the way Windows is interpreting the scaling.
Might be useful to show a screenshot of the whole maximised window from a new show.
Does it help if you resize the window rather than maximise?
Resizing / maximizing Titan has no effect on the context window button problem.
Here's a full screen capture (which will look super large on non-retina displays!)
- Attachments
- Full screen, Lenovo Yoga 2 laptop 3200x1800 native res
- Screenshot-(2).jpg (231.66 KiB) Viewed 13534 times
Here's a JPG resized to 1000px wide in case the previous image is unhelpful.
- Attachments
- Screenshot-(2)-resized-1000px.jpg (98.6 KiB) Viewed 13534 times
Thanks. If you don't mind could you do one from a new show please? I'm interested to see how the fixtures and groups buttons layout. Resized is perfect.
Sure thing. Here you go!
(I'd posted the Patch window, as it shows the problematic third row of buttons in the "Patch View - Patched Fixtures" context window).
- Attachments
- Screenshot-(3).jpg (111.82 KiB) Viewed 13533 times
Great, thank you. I will raise this for investigation. In the meantime you may be able to workaround by changing the display resolution although I realise this is less than ideal.
I just noticed that I see this exactly same problem when using a 3200x1800 display with Titan One. The buttons in the context window get cropped.
Do I need to submit a separate bug report?
I'm having this problem too. did anybody ever find a fix for this ?
Sadly, it has NOT been fixed in v9.1.
