Odd behaviour with copy and unfold function
Quidam
Postby Quidam » 21 Feb 2015, 01:09
I found a strange thing while trying to use copy and unfold functions simultaneously...
Here's the steps ; I wonder if someone else can reproduce it.
- Create a pb on pb fader 1
- Create a three steps Cue List on pb fader 2
- Raise pb fader 1 so it won't vanish when unfolding
- Unfold cue list
- Move pb1 to pb fader 5, right next the last unfolded cue
- Refold cue list
- Press Move, press swop of the pb1 (fader 5)
- Press Swop of the cuelist.
----> Pb1 moves ok but Cuelist 'disappears', instead of swapping place with pb1.
If you create another cuelist and unfold it, you can actually retrieve your first cuelist, as it pops on one pb fader, and get it back by moving it to playback window, refolding then moving to a pb fader.
It seems the cuelist is lost in the 'Unfold Space' - which is actually kinda cool... But I guess it's not what was intended.
Re: Odd behaviour with copy and unfold function
Postby niclights » 21 Feb 2015, 11:35
Confirmed. I will put it in the system. Thank you!
