Hi. I can't understund how to copy cue in the same cue list, so that the copied cue contain tracking information.
As an example, when I copy cue 3 to cue 10, the 10th cue contains the tracking information only from cues 1, 2, 3.
How can I do this??????
copy cue in a same cue list
Re: copy cue in a same cue list
actually the question is how to'' include'' cue with tracking values..?
If I understand you correctly. the cue # 10 (as a copy of #3) will only contain information that was put into cue 3 when it was programmed and unless you have made a blocking cue between 3 and 10 then all info will track forward anyway.
If you copy rather than include that is:
Copy (hit cue stack hard button) then type on keypad 3@10 (enter)
Looks like there some interesting new tracking developments in Titan V9 though.
