console in boot mode
I have two consoles: 1 Avolites Titan one 1 Avolites Titan mobile. Both consoles are botting mode and do not want to leave. As I can make out of this mode.
Re: console in boot mode
Try reprogramming the firmware of each device, it is best to do this with only one connected at a time. In USB Expert Console under the Service tab there is button labelled Program. When you click it you will be prompted for the firmware file to use, these can be found in C:\Program Files (x86)\Avolites\UsbExpert\Panel Software. The file titan_one.bin is for the TitanOne and m_mb.bin is for the Titan Mobile. Please ensure that you select the correct firmware and do not unplug while programming is in progress, as this could irreparably damage the hardware.
