v. 8 for Pearl Expert?
illumn8r
Postby illumn8r » 01 Sep 2014, 18:04
Where is it? I swore I saw it a few days ago, camee in on a day off to install to make sure there were no issues and now it's gone! Version 8 is there for other consoles but not for PE.
Re: v. 8 for Pearl Expert?
Postby niclights » 01 Sep 2014, 18:41
The link has been temporarily removed while a potential issue specific to the Pearl Expert is investigated.
illumn8r
Postby illumn8r » 01 Sep 2014, 18:51
My luck LOL. OK thanks :-)
clublights
Postby clublights » 02 Sep 2014, 00:27
illumn8r wrote:My luck LOL. OK thanks :-)
I'd call it GOOD luck if there is an issue that popped up lol ... Your not stuck fighting it!
illumn8r
Postby illumn8r » 05 Sep 2014, 01:08
Oh true, I agree, just meant it was my luck to not check before I drove the hour in to work from home just to do the upgrade and test it only to find out the upgrade was no longer there. Should have checked before I left the house and I was able to work on a few other things so not a complete waste or anything at least :-)
Olie
Site Admin
Postby Olie » 09 Sep 2014, 14:14
The setup's for Pearl Expert V8.0 are available again from our website.
StijnS
Postby StijnS » 09 Sep 2014, 21:18
If we already have the previous V8 installed on an Expert, do we have to run the installer from the website again?
Olie
Site Admin
Postby Olie » 10 Sep 2014, 17:40
Yes, if you previously installed V8 before 5th September then you should update using the new installer on the werbsite. In the About box under tools you should see 8.0.50.5 listed for Titan.
