No DMX output Titan Mobile after installing 7.5
ehal_no
Postby ehal_no » 18 Jun 2014, 21:26
After installing Titan 7.5 there are no DMX output. In the DMX window I can observe that there are output. What to do?
Re: No DMX output Titan Mobile after installing 7.5
Postby niclights » 18 Jun 2014, 21:27
Are the outputs assigned in DMX Settings?
ehal_no
Postby ehal_no » 18 Jun 2014, 21:35
Thanks. :D Now it works. But what is the reason why the DMX settings where empty?
Postby niclights » 18 Jun 2014, 22:07
Not sure. Can only assume they defaulted to unassigned. If you load a show with [Load DMX settings from showfile] enabled then they should come back.
ehal_no
Postby ehal_no » 19 Jun 2014, 21:19
Ok. Since I got the same problem on both the main and spare machine, it is very likely that the DMX settings set to empty by default. After setting them manually, it worked yesterday afternoon on the spare machine. Tomorrow I will try your suggestion to load a show file on the primary machine and see what happens. Regardless it works by using the menu item to set the DMX settings. So I'm satisfied. Thank you :-)
ehal_no
Postby ehal_no » 28 Jun 2014, 19:10
And it worked on the main computer after loading an old show and accepting to keep DMX-settings form show. So all is OK.
