Rogo speed to fader
uoc
Rogo speed to fader
Postby uoc » 06 May 2014, 13:03
Could you assist with how to put rogo speed to a fader. I've tried to record to 100 % rotate speed, but it just snaps to that value.
Having similar problems with dimmer on the minimac (set to intensity mode)
samdissoire
Re: Rogo speed to fader
Postby samdissoire » 06 May 2014, 14:25
try this:
Edit times / mode 2 (fade to fader)
Postby niclights » 06 May 2014, 17:42
Exactly. If you want LTP attributes (everything except dimmer) to be controllable by fader set the playback to mode 2.
Record the attribute value you want to output when the fader is at full then manually set the attribute value you want to fade from.
