Icon folders
Nicke Löfgren
Icon folders
Postby Nicke Löfgren » 25 Jan 2014, 09:01
Where can you find icon folder in windows tree
If you make your own gobos / color and want to put them in the correct folder. :D
Re: Icon folders
Postby Gregory » 25 Jan 2014, 11:56
The on-screen keyboard will allow you to import standard image formats from your My Pictures folder or from removable USB sticks. In Windows 7 you can find the My Pictures under your Documents folder or in the Pictures library. The fourth tab on the keyboard will allow you to import images, once you have done so they will appear in the third tab under Imported.
Nicke Löfgren
Re: Icon folders
Postby Nicke Löfgren » 25 Jan 2014, 18:15
Well, that I know!
But I wonder where AVOLITES original is
Re: Icon folders
Postby Gregory » 25 Jan 2014, 18:26
My apologies. The Avolites icon library is in the Application Data folder under Avolites > Icon Library. However they are in a custom XML/SVG format.
Nicke Löfgren
Re: Icon folders
Postby Nicke Löfgren » 25 Jan 2014, 19:53
Is it possible to add your own there? Using the same format
Re: Icon folders
Postby Gregory » 26 Jan 2014, 21:15
In theory more could be added by copying items from your history or files you have previously imported.
Nicke Löfgren
Re: Icon folders
Postby Nicke Löfgren » 27 Jan 2014, 19:27
It was not easy! :oops: :oops: :oops:
So want to get gobo in the right place or color
