Wonder if I programers wrong
I've done a lot of playbacks. some only with colors.
When I "press" on these playbacks lit every "button" up.
You have to double tap to "extinguish" them
Is it possible to get playback button momentan? Type as Martin Light Jockey
Why I want only playbacks is that the staff in the restaurant should not have to press the wrong and not see all the other features of the Titan One
Momentan playback
- Nicke Löfgren
Re: Momentan playback
If playbacks are recorded to the Playbacks workspace window the default key profile action for Touch buttons is to Latch. You can either change the key profile for all playbacks or on a per-playback basis.
To change the key profile for all playbacks:
- Right-click on the Avo button.
- Select softkey G [Edit Current Key Profile].
- Press softkey A [Add 'User 1'] to create a new key profile called User 1.
- Select softkey D [Cues] then softkey D [Touch].
- Select Flash from the list (there are also options for Timed Flash and Swop).
- Press Exit to finish editing the profile for Cues.
- At this point you can change the key profile for other things including Chases and Cue Lists.
- Press Exit to return to the main menu; the new key profile is now active.
- Press softkey B [Playback Options].
- Find and select the softkey labelled Key Profile Global by pressing softkey F [Next].
- Choose an already created key profile from the list or select softkey B [Add New] to create a new one.
- Press softkey A [OK] to confirm the name of your new key profile.
- Select softkey D [Touch].
- Select Flash from the list.
- Press Exit three times to return to the main menu.
- Nicke Löfgren
PERFECT
Now I'll test it
Now I'll test it
