Shape size and speed on the fader
Nicke Löfgren
Postby Nicke Löfgren » 31 Oct 2013, 22:43
Can someone help me make a simple manual in shape size and speed on the fader? :D :D
My desk Tiger Touch
Re: Shape size and speed on the fader
Postby niclights » 31 Oct 2013, 23:40
I'm not sure I understand what you are asking.
Shape size or speed on fader is toggled via [Playback Options].
Press [Playback Options] followed by the playback handle containing the shape(s). Use the two softkeys to change whether the size or speed is fixed or controlled by fader.
When controlled by fader the fader will proportionally control the chosen parameter(s). A fader at full = the recorded value of the parameter.
Nicke Löfgren
Postby Nicke Löfgren » 04 Nov 2013, 08:19
Should explain a little better. :mrgreen:
When I programers a shape so I use the wheels for speed and size.
There will be a fixed value when I put it in a CUE.
I would for example like to have a tilt movement that stands still until I pull up a fader, becomes first 0 while I slowly pull up the fader begins tilt get bigger
(Fader = slide rule) :roll: :roll:
Hope you know what I mean :oops:
Nicke Löfgren
Postby Nicke Löfgren » 04 Nov 2013, 08:37
download manual :-)
Think I found in chapter 6:3 :D :D :D :D
I try
Users browsing this forum: Bing [Bot] and 49 guests
