Titan Remote, Troubleshooting and expected behaviour?
Beast
Postby Beast » 29 Oct 2013, 12:20
Hello all.
Have just used the remote for a focusing session in an amdram.
PE running 7.0 ofcourse, and Iphone 4s IOS 7.3. Initially having problems connecting and staying connected.
Solution: scanning the wifi channels, showed much activity/noise on the routers preselected channel. Changing this
manually solved the problem. Make sure to disable the auto lockscreen on Iphone, mine disconnected when the lock
engaged.
Observation: worked fine, with a little latency. Phone ran out of battery and closed down during the end, with a channel
at 60. There was no way i could turn this of, not even on console/other phone. Powered the Iphone up again, and presto:
regained control of the channel. Dont know if this is expected behaviour?
Didnt try restarting console, would probably solve .
Anyway, saved me tons of climbing and walking, so good work AVO👍👍.
Regards
Beast DK
Re: Titan Remote, Troubleshooting and expected behaviour?
Postby Gregory » 29 Oct 2013, 12:34
Both on the console and the remote, if you hold down the Clear button there is an option to Clear All Programmers. This would allow you to clear the value of 60 that was left on by the remote from the console.
Beast
Postby Beast » 29 Oct 2013, 18:20
Yes ofcourse!!😉
