Selecting fixtures from key pad
Is it possible, using Titan v7, to set the key pad to fixture recall instead of having to select the fixture button, then the fixture number? I would like to be able just to type in my fixture number and then press enter when I am programing without the extra step. Iain
'Who you jiving with that cosmik debris?'
Re: Selecting fixtures from key pad
This is already the case, provided that you are not in some other menu that requires keyboard input, you can type in fixture numbers directly. For example, if you press Avo+Exit (to exit all menus) then type in 7 THRO 12@@ it will assume you mean fixtures 7 through 12 and set them to full. If you press Enter instead of @@ then you will just select the fixtures.
Thank you. It was the @@ i was missing for a single fixture.
Users browsing this forum: Bing [Bot] and 49 guests
