pearl 2004 to expert V6.1
uldis
Postby uldis » 23 Sep 2013, 10:37
what is the easiest way to get pearl 2004 show to the pearl expert v 6.1 console?
Re: pearl 2004 to expert V6.1
Postby niclights » 23 Sep 2013, 10:45
Unfortunately there is no way to convert between Titan and Classic. You can still run Classic on the Expert and load it into that but if you want to use Titan you will need to reprogram.
uldis
Postby uldis » 23 Sep 2013, 11:02
sad! I have a lot of classic theatrical shows who will be working for a long time. classics have already been sent to retire, but brutally overwrite each channel value is quite tiring and there are many opportunities to let errors.
uldis
Postby uldis » 23 Sep 2013, 11:25
what would you do if you had to be rewritten classic show to the titan?maybe it is possible by sending a DMX from the classic to titan?
Postby niclights » 23 Sep 2013, 12:14
Sorry, there's no way to capture DMX in Titan at the moment. I appreciate it is not ideal to have to reprogram from scratch but I don't think there is any other solution. All I can suggest is running the console in Classic mode for the short term while you spend time programming in Titan. Note that you can do all this offline on a PC if it helps (you can run both the Pearl 2004 Simulator and Titan Simulator at the same time). This should also give you a chance to become more familiar with Titan and make use of the improved functionality.
