Hi!
I try to connect Katrin Media server on MacBook Pro and Titan Mobile with CITP protocol.
Everithing it's ok, but thumbnail exchange stops after 300-400 thumbnails recieved.
Tryed to do the same with Arkaos MediaMaster (PC version). No problems...
Thank you!
katrin media Server CITP/MSEX
Billyserious
Re: katrin media Server CITP/MSEX
How did you get mediamaster to show up as an active fixture? Ive been working for weeks and no luck with a mobile, an expert, and MM 3.1. I can grab control via just regular patching, but nothing for active fixtures and thumbnails.
@billyserious: Have you tried following the detailed instructions I wrote for you in response to your original question here?
Apologies to the OP. Unfortunately I don't have any ideas regarding your problem at the moment.
Hi maybe a little off topic regarding to the posts before,
I have a TT and a arkaos media server(running media master in fixture mode)
Tried to set up the msex protocol, everything works just fine. Except te sync between between the two machines,
The Msex bulb/lamp is green in arkaos, synced once but never again
System is connected by art-net
TT does not show pics or new added maps.
Thanks.
Thanks.
Billyserious
@nic
Yeha, thanks for that walkthrough, I can control and talk to MM now, yes, but I was reading into the OP's post that he was able to get thumbnails out of MediaMaster and therefore be patched as an active fixture, which I still haven't ever been able to achieve, if it is even possible.
Those instructions are all about getting it to patch as an active fixture with thumbnails. They work for me for both Titan Mobile on the same PC and Pearl Expert over a network.
Users browsing this forum: No registered users and 111 guests
