Titan Key Profiles
Lach
Titan Key Profiles
Postby Lach » 27 Aug 2013, 19:56
HI Guys,
It might be easiest if I explain my current setup on the WholeHog Playback wing before I ask my question. (Sorry if your not familiar with the Hog, but in my experience it pays to know more than one platform.)
At a regular club night I do (on the Wholehog PC), I set the far right playback channel as my strobe channel. I Set one cue at half intensity and another at full Blinder (Atomic 3000). I then use the "Choose" and "Left/Right" buttons to select which function I would like the button to execute. I use the same method on channel 9 to select between Duets, Sunstrips and 5x5 Blinder. Using this technique I end up with a "Matrix" style floating playback wing, It allows me to mix and match looks, cues and chases from different pages.
My question is this, Can I change the Key Profile to make the Swop button into more of a 'choose' button, like for instance on a Hog? For my workflow, its a pain to have to swop whole pages in order to access more cues/chases, then swop back to use my strobe/blinders etc. I understand that I can page lock selected chases (strobe for example), but that in turn would use 5 out of 10 possible playback channels (Tiger Touch for example).
Does this make any sense at all? Is there another much easier way to achieve my desired result?
Kind regards
EDIT: I should have mentioned that I mostly busk at this show, I spend a few hours ahead of time setting up all the looks and chases i want to use, then i play them back in elaborate and exciting sequences over the course of the night.
Users browsing this forum: Google [Bot] and 39 guests
