I am new to Midi and time coding.
I work in a venue that has alot of DJ's coming through it.
I am trying to get the Midi time code to set the speed of a chase or trigger the transition step change. ?
Midi Time code Triggering
rgerwatowski
rgerwatowski
Re: Midi Time code Triggering
Can the console sense BPM like previous Sound to Lights options ?
rgerwatowski
Tiget Touch
There are two options for controlling the Tiger Touch using MIDI, either using MIDI triggers or by MIDI timecode. MIDI triggers allow you to receive MIDI notes/commands and use them to trigger a variety of actions on the console, such as firing a cue or stepping through a cuelist. Alternatively, in Titan one or more cuelists can be setup to follow an incoming MIDI timecode source, where each cue in the list is given a time at which to fire, at which point the cue will be fired automatically. More information about triggers can be found in the Tiger Touch manual, section 10.4 on page 162. More information on timecode can be found in section 9.5.5 on page 152.
You can use MIDI triggers to set the Tap Tempo of a chase either on a specific chase, on the currently connected chase or on the BPM masters. This can be done by assigning the trigger to the physical button that has that set as the key profile.
I recently bought a Kenton Control Freak which is an eight fader/eight button, 127 page MIDI device. I was hoping to be able to use it alongside the Titan Mobile but the device didn't seem to recognise page changes on the Titan Mobile, so in effect I only had the eight faders on page one.
Is this a me thing or a you thing?
