Mobile - how to have 20 empty macro/executor buttons?
lightning
Postby lightning » 01 Jun 2013, 18:39
It seems I'm stuck with having the 11 thru 17 be the workspace callups as they are labelled such on the board and stay there when cycling thru pages..
Is there any way around this?
If not, is there a way I can assign button 18 on all pages to "go to page 1".. etc. or are you limited to one location per show library macro?
Re: Mobile - how to have 20 empty macro/executor buttons?
Postby niclights » 01 Jun 2013, 19:02
To delete workspace shortcuts you need to be in the view menu first. On the TM press Open followed by delete then select handles.
You can define whether handles are locked across pages via playback options - [Playback Options]/select handle/toggle [Unlocked/Transparent Lock/Locked].
lightning
Postby lightning » 01 Jun 2013, 20:00
awesome, i woulda never tried that :)
One additional question for the Mobile static playbacks... instead of push button = on, push button again = off. I want push static playback button and hold stays on, release static playback button turns off.
TIA..
Postby icke_siegen » 01 Jun 2013, 21:04
Change its key profile to 'flash'.
