HTP in RGB color mixing in Titan
luciolis
Postby luciolis » 30 Apr 2013, 07:49
Hi there.
I've been recently playing with some Robe 600 led copies ( :roll: ). I tweaked the fixture provided but have not been able to patch the RGBW channels into 4 playback faders to do some manual color mixing.
Do you know how to do that ? Apparently only dimmer channels are HTP and not RGBW channels.
Thanks in advance,
Adrian
Re: HTP in RGB color mixing in Titan
Postby niclights » 01 May 2013, 00:36
Record the individual components using 'by channel' mode and then set the playbacks to mode 2 in [Edit Times]. You will then need to set the components back to zero in order for this to work.
