Record Arcbar 3 look onto a playback, put fader to full scene replays fine, pull fader down arcbars stay on. have to record off command onto another playback to kill them.
any suggestions ?
using Tiger Touch V6.1 running Arcbars in stage1 mode.
LED ARCBARS
I'm assuming these are Showtec ARCBAR 3? If so, which mode did you patch in the console?
If you patched 'Mode 1, 12 DMX' this does not contain a virtual dimmer and so preferably you need to change to 'Mode 1 +vDim'. I don't know why there is a non-virtual dimmer. This should have been removed IMO.
Annoyingly I can see there appears to be a fault in the vDim code which means the Magenta attribute still won't be controlled by the dimmer. If you can't wait for an official update this is very easy to fix yourself either using Personality Builder or a cheeky text edit.
