TITAN mobile v6.1 Workspace Macros and Executers button
alim6310
Postby alim6310 » 29 Jan 2013, 13:08
hi, there,
my name is je=immy for jakarta indonesia, i'm using the titan mobile, i want to ask about the Workspace Macros and Executers button, there were 20 button, but it seem number 11 until 17 is already been use for the workspaces, can i change it for cue, thank, and 1 want thing i want to ask, can i use small midi controler ( small keyboard tuts ) with the midi connecter? thank u
Postby niclights » 29 Jan 2013, 13:23
To delete the factory workspaces press Open(View) then Delete, select handle and then press the softey to confirm when prompted.
You can use MIDI controllers which have standard MIDI connection. You cannot use controllers that use Usb. To setup the controller go to System/[Triggers].
alim6310
Postby alim6310 » 11 Feb 2013, 05:57
yes it's works.... thank u
