Azure 2000 Can't Save Playbacks/Edit Chases
Tallysrfr
Postby Tallysrfr » 03 Feb 2013, 18:07
When I try to save a playback, for a milisecond it says something about being "Out of Memory". Same with the chases. Can someone please help?
Thanks,
Bryan
Postby niclights » 03 Feb 2013, 19:40
I think one way or the other this does mean it doesn't have room. Try deleting things. If that doesn't work then perhaps try reverting to an earlier saved show? Sorry to be so vague but in the few times this has come up there I don't think I've ever seen a definitive solution.
Tallysrfr
Postby Tallysrfr » 04 Feb 2013, 12:36
What do I delete? I have pages of empty playbacks. I tried to reload the software but that didn't work, either.
Thanks,
Bryan
Postby niclights » 04 Feb 2013, 18:31
I really don't know. A playback or palette? I wasn't all that hopeful to be honest.
I actually suspect it relates to patched fixtures (which may have since been deleted). To see if there is a history of legacy fixtures open patch view with a VDU connected - they will all be listed on the right-hand side. If there are lots of fixtures there that you don't actually use then that is likely the problem.
Ufortunately there is no way to remove them. That is why I suggest loading an older version of the show if you have one.
Tallysrfr
Postby Tallysrfr » 04 Feb 2013, 21:39
I guess this is my ignorance showing, but what is a VDU and where would it be connected to the board? Would it have to do with the Visualizer? Because I have one on my laptop for the TitanOne(waiting for a dongle), but I cannot connect one to the Azure 2000 board because I need a special rs-232-to MIDI In/Out that I don't have. I don't have a tablet either, just the board.
Thanks again,
Bryan
Postby niclights » 04 Feb 2013, 21:45
A VGA monitor using VGA port.
Tallysrfr
Postby Tallysrfr » 04 Feb 2013, 21:53
Oh. Okay. Got one of those. I did limit the DMX to 256 instead of 512 to shorten the refresh rate. Could that be the problem. Usually, I have this problem only momentarily and clears up after a reboot. But it's sticking around this time. The same with the chases as the playbacks. Only the memories for the chases are somewhat held on the playback, you just can't do anything with them and have to use the "Cut" function to get rid of them.
Thanks,
Bryan
