Visualizer Setting
Posted: 27 May 2022, 12:21
by NMSK
When the moving light was placed on the visualizer, it was inverted from its actual appearance.
It is actually oriented toward the front.
Is there any way to change the settings using Capture or other means?
Using this
・Titan Ver 13.0
・Fixture - Light House Limited/HL-150 Hybrid
・Capture 2022
https://d.kuku.lu/689f66f21
Re: Visualizer Setting
Posted: 27 May 2022, 12:55
You can adjust the orientation of selected fixtures in the integrated Capture Visualiser by toggling the wheel mode on softkey G to 'Wheels=Visualiser' which will connect the wheels to visualiser properties. Position and orientation can be found on the position bank (pressing the position attribute bank button will cycle through various pages of position and orientation properties). On moving fixtures there will usually be a rectangular box on one side of the base representing the fixture's LCD display and this can be used to orientate the fixture.
Note that the accuracy of the simulation is dependent on the information available. If, after orientating the fixture in Capture to match the real world, the pan/tilt positions don't match then please submit a request via the form on the personality website explaining this in the notes section. We can then send you a pan/tilt calibration guide which contains three questions in order to calibrate the fixture.
