all personality and fixture are gone
all fixtures is gone on my visualiser i dont know what happen. how do i restore it thnx
Re: all personality and fixture are gone
If you have added any custom personalities please remove them and restart the Visualiser software. If that is not successful download and run the latest personality installer from the website.
sir if that is the problem how could i use the costum personality??
If the fixture list is blank it suggests that the custom personality has an error in it which is preventing it from loading. You will need to fix the error with the personality before you can use it. If you can post the contents of the file here we may be able to spot what is wrong.
; 'Unknown 230 Beam', 20 DMX Channels, filename: UK230WBM.R20
; Copyright © Avolites Ltd. 2017
; Date By Description
; 01-04-14 Nic Morris Created
; 24-12-17 Pers Creator Created - Exported from Diamond 4 file.
; The device name, upto 11 characters, no spaces are allowed
DEVICE UK230WBM mode=20 DMX 20 DMX Channels
NAME "Unknown" "230 Beam"
; The Type of instrument, 1 & M must required for backward compatibility
; The middle number denotes the number of DMX channels used
TYPE 1 20 M
; Mirror/Head resolution
MIRROR 2 540 250
; | | |_______ maximum tilt movement (in degrees)
; | |____________ maximum pan movement (in degrees)
; |_________________ 1 means moving mirror, 2 means moving head
; Patching Information. (Upto 10 lines allowed)
; Upto 10 lines of 159 chars are allowed including formulae
; Variables used d=dmx number(1..512), h=handle(1..60), n=devicename (11-char)
; Allowed modifiers
; +,-,*,/,(,) basic arithmatic
; % means remainder after divide
; & means logical AND
; | means logical OR
; R means reverse the bits of the current result (operates on a byte)
; ^ means logical Exclusive OR (operates on a byte)
; > means shift to the right
; < shift to the left
; r followed by number means get the value of that parameter
; d DMX address
; n Fixture name, a 0 terminated character string
; h The handle number
DEVICEADDRESS
"Handle %2d"h
"Fixture %11s"n
"DMX %03d"d
"Set to 20 DMX"
DAEND
; Specify DMX limits
; minimum allowed dmx number
MINDMX=1
; maximum allowed dmx number
MAXDMX=492
; DMX number must be divisible by this
DIVBY=1
; DMX channel description
; 1. The channels bank number (1..20)
; 2. The upper faders in the bank (1) or the lower faders in the bank (61)
; s=16-bit Fadeable LTP
; 4. DMX offset (1..number of DMX channels)
; 5. The output level is proportionally reduced by this level (0..100%)
; 6. The curve number (applicable only to HTP channels), usually set to 1
; 7. Inverted (I) or Normal (N)
; 8. Attribute type (A=Colour Wheel 1, B=Cyan, C=Magenta, D=Yellow,
; E=Pan, F=Tilt, G=Iris, H=Dimmer, I=Gobo1, J=Gobo2, K=Gobo1 Rotate,
; L=Focus, M=Gobo2 Rotate, N=Colour Wheel 2, O=Shutter, P=Prism, Q=Zoom,
; R=Effect Rotate, S=Frost, T=Red, U=Green, V=Blue, 0=uncategorised)
;10. Attribute name, must be enclosed in quotes and upto 12 characters allowed
;11. The ON value of this channel (0..255)
;12. The Highlight level of this channel
;13. The Lowlight level of this channel
DMX
2 61 L 12 100 1N O 1 "Shutter" 255 0 0
1 1 H 13 100 1N H 1 "Dimmer" 255 0 0
3 61 s 1 100 1N E 1 "Pan" 127 0 0
0 0 L 2 100 1N E 1 "Pan Low" 127 0 0
3 1 s 3 100 1N F 1 "Tilt" 127 0 0
0 0 L 4 100 1N F 1 "Tilt Low" 127 0 0
4 1 I 7 100 1N A 1 "Colour" 0 0 0
6 1 I 6 100 1N I 1 "Gobo" 1 0 0
5 61 L 10 100 1N L 1 "Frost" 0 0 0
5 1 L 11 100 1N Q 1 "Focus" 127 0 0
9 1 I
Reason: wrapped in code tags for fixed width font
The file is incomplete. This is almost certainly because of a wheel mapping conflict. In Personality Builder check that all the attributes are assigned to separate slots in Classic Pearl wheel mapping. Drag and drop anything in red to empty slots.
ok sir thankyou very much
have a nice day
have a nice day
