Fixtures missing?
Posted: 13 Jan 2015, 21:21
by akepaulsson
When i try to patch a bunch of Showtec Phantom 75 Beam, they don't auto patch so I tried to manually ad them and from what I can se the fixture files after the letter "L" is missing. The last fixture in the list is LEDJ-Tri-PAR 64. Or is there something I don´t understand? (TT 8.1).
Best regards Åke Paulsson
Re: Fixtures missing?
Posted: 13 Jan 2015, 21:42
There is no visualiser file for the Showtec Phantom 75 LED Beam at the moment. I see you have put a request in for it so I will get that created.
The problem with nothing showing after L might be due to your theatre. Try loading 'blankmm.ttr'.
Posted: 28 Jan 2015, 16:50
by akepaulsson
I have tried to load the "'blankmm.ttr'" and all the fixtures is showing up, so how do a correct the problem with the fixtures not showing in my own "normal" theater?
Posted: 28 Jan 2015, 17:02
Unfortunately I'm not sure if you can. If you load blankmm then load your theatre does it break again?
Posted: 28 Jan 2015, 21:20
by akepaulsson
Now it's working. I opened the "mm" version, closed it and realoaded My standard Theater. Thanks for great help!
Posted: 23 Oct 2015, 12:03
by clapcreative
Here is also not working.
