I loaded the 2004 simulator to try out and after a few minutes I get a "sort it out!!" error.
I went back to the 2000 simulator and all works fine.
any ideas on what I may be doing wrong?
TIA
Jason
2004 sim and vis error
This message is caused by a previous installation of Pearl Simulator. There is a simple registry patch that can fix it.
Please follow these instructions:
1) Open Notepad
2) Copy in the following code
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Avolites\Pearl\PearlSimulator]
"ZoomedButtons"="0"
3) Save with the filename "SimFix.reg" NOT ".txt"
4) Double click on the file you have just saved.
5) Select Yes when prompted "Do you want to add information to the registry?"
6) A message should be displayed to indicate it was sucessful.
It should all now work fine!
1) Open Notepad
"ZoomedButtons"="0"
Users browsing this forum: No registered users and 1 guest
