looking for *.R20 file for Synchrolite SX3K
Posted: 20 Nov 2004, 13:13
by jop
Does anybody have the personality file of the Synchrolite Sx3K SPot en Wash to use with the Avolites Visualiser???
I need it quite urgently to use abroad.
If it exists, could someone tell me where I can find it?
Thank you,
Jop
Posted: 25 Nov 2004, 22:55
by Low_ID
You must use the SYS3K.R20 file from the disk number 6 of personalities.
This file is controlling 9 dmx channels, as well as the SX3K, although it is wrongly associated to the ST3K model of Syncrolite, wich is a static fixture and is therefore using four less channels than the moving one.
You might use also the SYNCRO.R20 file (Syncrolite Unit). The only differences between them are the Focus locate position (50% vs 0%) and the Pan/Tilt resolution (540º/250º vs 150º/110º)
Download the disk number 6 from the Avolites Fixture Personality Library
