simulator help
simulator help
'ACW service No installation' WHY?
Could you please be a little more specific?
- with which program do you have this problem, and in which situation (I just guess you're trying to get the Titan Simulator running)
- what is your operating system?
Does it say 'not installes' or 'not running'? If not installed, the best thing is to remove all simulator-related programs, then make sure Dotnetframework 3.5 is installed, and install again. If 'not running', try starting the service manually.
See this post: http://www.avolitesshop.co.uk/phpBB3/vi ... php?t=1933
Do you get a dialog box that looks like the following when Virtual Panel launches?
If so, do the following:
- Close Virtual Panel
- Go to Start Menu/Programs/Avolites/Usb Expert Console
- In the Usb Expert Console window go to the Tools menu, select ACW Service/Start.
- Wait a few seconds for it to start and then close the Usb Expert Console window.
- Start Virtual Panel again (Start/Programs/Avolites/Virtual Panel)
"ACW Service not running."
'The ACW Service has not been started on this computer.
Please start the ACW Service before running the program.'
icke_siegen wrote:Could you please be a little more specific?
win7 32bit notebook
Unable to delete USB EXPERT,not runing too.
niclights wrote:Do you get a dialog box that looks like the following when Virtual Panel launches?"ACW Service not running."
click ACW Service/Start,Not reflect.
Where to start?
1. Try to start the service manually. Open a console window (Win+R, cmd), and type: net start "Avolites Expert USB". What does it say?
On my german XP desktop, it looks like this:
In the last line, it says 'Service successfully started'.
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Dokumente und Einstellungen\sb.TRENDCO>
C:\Dokumente und Einstellungen\sb.TRENDCO>net start "Avolites Expert USB"
Avolites Expert Usb wird gestartet....
Avolites Expert Usb wurde erfolgreich gestartet.
Users browsing this forum: No registered users and 2 guests
