Finding heads in Visualiser
Posted: 03 Oct 2010, 11:15
I am New to the Visualiser . and haveing a struggle getting started. All the software is loaded ok.
I go into design mode ok
Then when i select "MH" I look at the drop down and can find about 6 fixtures.
I look in the Preference box for File Paths and notice both Extensions and Personality file path point to the same extension directory.
I change the personalities to the correct path ( looking at R20 file).
Both Extensions and Personality directories have loads of heads both .vis and R20 in the correct Directories.
However when I go back to the Drop down to select a head I still find the original 6 or 7 heads and not the long list to choose from.
Left scratching head
What am i doing wrong
PS running it under Windows 7 If I select one of the few heads then i can see it in on the screen and use it but can not get to the heads I need
