				visualiser dongle?
				Posted: 10 Feb 2010, 19:33
				by kentn
				hi do i need to have a dongle to use the visualiuser with the simulator, and a tiger consol?
				Posted: 10 Feb 2010, 19:46
				You don't need a dongle any more.
If you wanted to actually connect the console you might need ACDI.
				Posted: 10 Feb 2010, 20:37
				by kentn
				i have tried do a patch in both vis and sim.
but i dont think they connect. i am pretty sure that the dmx adresses are correct in both vis and sim. and i choose simulator in vis in the radio butons.
any idea what i am missing?
edit, what is acdi?
				Posted: 10 Feb 2010, 20:50
				ACDI
But you definitely don't need this for a simulator and Avolites Visualiser running on the same machine.
In Vis, create a new theatre and add a single generic dimmer at Univ A, DMX 001.  Change to Run mode.
In Simulator Patch one dimmer to a handle on output A, DMX 001.
Raise/Lower the relevant preset handle and you should see results in Vis.
				Posted: 10 Feb 2010, 20:52
				by kentn
				i got it connected. but i cant what i am doing during programing, but when i run the the show i can se the heads moving.
edit. okay, i can se heads moving, but i cant the beam on the heads, it is futurelight phs 575. i have raised handle 1-4 where i pathed my lamps.
the shutter is is set to open, but no beam?
				Posted: 10 Feb 2010, 21:16
				by kentn
				it is up running with simulator.
thank you for helping. maybe ill be back when i try connect the console.
