Dongle error even with Dongle plugged in LPT
Colin
Postby Colin » 26 Apr 2004, 16:07
Does anyone know how to solve the dongle error? I have a dongle plugged in.
When even i click the "Simulator" option in the visualiser, my Simulator is running also.
Thanks :D
Olie
Site Admin
Postby Olie » 26 Apr 2004, 17:47
If you are running XP then please ensure that you have installed the XP dongle drivers under the Start Menu|Avolites|Visualiser. Also that you have read and followed the Visualiser Quick Start Guide.
If you are still unable to get the dongle to work then please contact Avolites by email using my email button at the bottom of this post.
Colin
Reply
Postby Colin » 27 Apr 2004, 02:15
Thanks for the fast reply. Im using windows 2000, but will install the Dongle drivers nonetheless.
The_Enigma
Postby The_Enigma » 02 Feb 2005, 18:29
Despite the installation of the drivers and a dongle I still have problems.
The software doesn't "see" the dongle.
I will send you an email.
Thumper Audio + Lighting
Postby Thumper Audio + Lighting » 02 Feb 2005, 20:28
Have you tried to see what settings your LPT port are; under the bios settings?
It should be set to [EPP] mode. see if that may be the problem. I had this problem when I upgraded a motherboard last year. the defaults were set to [ECP+EPP] mode.
Jason
The_Enigma
Postby The_Enigma » 03 Feb 2005, 07:01
Thumper Audio + Lighting wrote:Have you tried to see what settings your LPT port are; under the bios settings?
Jason
I checked it.
There were 3 choises and I tried all 3 of them, but nada nothing.
Still the darn error.
I noticed that despite of my bios settings, W2K uses always the same driver.
ECP Printer port (LPT1)
So I manually removed that driver and forced windows to load the driver named Printer Port (LPT1).
Checked it but the error remains. :(
Proto_Cool
Postby Proto_Cool » 03 Feb 2005, 09:39
You better use the "License" tool, under Start>Avolites>Visualiser>Tools.
This will give you a computer key that tou send to Avolites with your Visualiser's serial number and they will return tou you an activation code that allows one computer to run the visualiser without a dongle.
This is the quickest way if you already tried with the conventional way with no results.
Proto_Cool
The_Enigma
Postby The_Enigma » 03 Feb 2005, 16:26
Do you know to whom I should send that serialnumber?
I've send an email to Chris and to Oliver (asking them for a solution), but they haven't replied :?
Proto_Cool
Postby Proto_Cool » 03 Feb 2005, 21:02
When you run the License program you get instructions (mail address included) on how to proceed.
Proto_Cool
Olie
Site Admin
Postby Olie » 04 Feb 2005, 09:40
I am afraid that I have not recieved any emails from you.
Maybe you could try again with the email address from this post.
The_Enigma
Postby The_Enigma » 07 Feb 2005, 09:11
I received your email and I have send you my computer key.
cheers
The_Enigma
Postby The_Enigma » 09 Feb 2005, 22:04
Hi Olie,
I've send you an email on Sunday and today.
Can you confirm that you received them?
I'm waiting for the license key, since the dongle
doesn't work (and yes, I've send in the PC key).
It would be great if I finally could start working the visualiser.
The_Enigma
Postby The_Enigma » 10 Feb 2005, 18:47
