I have problem with the Visauliser.
I just added 8 "Varytec - Hero Spot 90" and all of them show up.
But when I locate them only the first fixture that I patched gives light.
All of them moves with pan and tilt.
If I remove the one that gives light from the patch, the second one starts to give light but no others.
So one 1 fixture at a time.
What am I doing wrong?
Regards /Chrille
Only got light on 1 fixture but can control them all
chrilleericson
Re: Only got light on 1 fixture but can control them all
It seems ok when I test. If you haven't done so already it might be worth downloading and installing the latest Titan Fixture Library appropriate to the version of Titan you are running in case there was a fault with the Capture fixture in an earlier version. Does this happen from a new show (preferably test after installing the library to be sure)?
- suic1de_messiah
Hello, i summoning this post because I'm having the same problem now with v15.1 and capture.
Problem is the same, one thing I can add is: if I create 10 groups with 10 fixtures within each group, only the first fixture of each group turns on.
I checked everything I could, patch, personalities (update to the most recent version).But no luck so far.
Is there something I didn't tried yet?
Thanks in advance for the help.
Which fixtures and which mode exactly are you using?
