When i try to patch a bunch of Showtec Phantom 75 Beam, they don't auto patch so I tried to manually ad them and from what I can se the fixture files after the letter "L" is missing. The last fixture in the list is LEDJ-Tri-PAR 64. Or is there something I don´t understand? (TT 8.1).
Best regards Åke Paulsson
Fixtures missing?
akepaulsson
Re: Fixtures missing?
There is no visualiser file for the Showtec Phantom 75 LED Beam at the moment. I see you have put a request in for it so I will get that created.
The problem with nothing showing after L might be due to your theatre. Try loading 'blankmm.ttr'.
akepaulsson
I have tried to load the "'blankmm.ttr'" and all the fixtures is showing up, so how do a correct the problem with the fixtures not showing in my own "normal" theater?
Unfortunately I'm not sure if you can. If you load blankmm then load your theatre does it break again?
akepaulsson
Now it's working. I opened the "mm" version, closed it and realoaded My standard Theater. Thanks for great help!
clapcreative
Here is also not working.
