vis files
kevin charge
vis files
Postby kevin charge » 22 Nov 2005, 21:55
Hi
I am after vis files for james thomas eng pixel line 1044, and martin mac 700 has any one created the files for visualizer?
Cheers
Kev.
Ed
Postby Ed » 23 Nov 2005, 10:03
Hi Kev,
The Visualiser files for the Martin mac 700 Should already be in your library. The naming for the Martin fixtures could perhaps be a bit clearer! You can download the Vis personality for the martin Mac 700 here: http://www.avolitesdownload.com/Persona ... 3&Desk=All
There is not a Visualiser Personality for the Pixel Line yet but the fixture would be hard to repesent in visualiser. At present the visualiser only supports moving head and moving mirrors.
Phil
Postby Phil » 24 Nov 2005, 16:44
I did something on the lines of a Pixel Line (it was actually a ChromaBank) over the summer for someone. Assuming you're using it in RGB mode (rather than the 10 channel MAX2 mode, you can represent each RGB cell with one generic RGB head.
From memory, under the moving head menu you should find a Pulsar Chroma Fixture somewhere. If you select that, then by setting the height, width and depth to something relatively small and setting the offset of next fixture so they sit next to each other you should be able to create some sort of pixel lineish effect. You may also need to play with the beam angle for the fixtures to stop it all getting too messy.
If you're wanting to use MAX 2 mode though, you're going to be completely out of luck.
