Azure 2000 (Software 2003) Memory Full Problem,
Posted: 19 Jul 2004, 08:04
Hi There,
I'm working on a nightclub with the Azure 2000.
We're using this desk for only one week now, and only have programmed 2 banks with Presets (A & B) after that we noticed a lot of strange problems, move's were not working anymore and copying (colour, gobo, prisma) presets was IMPOSSIBLE.
After a while we found out that the Avolites Azure 2000 was out of memory space.
We're using about 4 different spots (10x Robe Wash XT, 10 xRobe Spot XT, 50 x Showtec Genesis 3 & 2 Strobo's.) And only have programmed Bank A & B
We saved all info to disk, and then used the "Wipe All" function.
Then placed back the "show from disk" and suddenly we've had 62% memory free. Is this a known problem????
The manual also says that using the "CUT" function has to work like "ctrl-x" in windows and saves the preset to "Temp Memory" before u "Paste" this preset to another button.
When i use the Cut function my preset is removed but i can't Paste this to another position.
We also had a chip deliverd with the Azure Table, what's should we do with that ??
Thanks for your help.............
