Posted: 05 May 2007, 18:05
So if it doesn't restore the dipped output when you lower the mode 3 memory - what's the point? Or do you mean it's meant to and just doesn't work properly? In which case, I can say it again - what's the point!
· Mode 3 - Crossfade cue. All channels, including intensity channels, will fade to the settings in the new cue. All other cues fade out and all other active playbacks become inactive; if you need to re-fire a playback, take the fader to zero and put it up again.
