azure chase bug (losing step 10 info after setting times)
Posted: 14 Jan 2007, 05:36
If I program 10 steps or more into a chase, then at any time after, edit the times or links globally, (ie use "set time" on the chase playback) step 10 loses its information.
Its still treated as a step, but there is nothing there.
Its not a problem if you program less than 10 steps, exit, edit times or links, then continue programming as many steps as you want.
Nor a problem if you unfold, edit each step one at a time, refold.
But if you go anywhere near the "set times" on the chase playback, step 10 info is gone.
Lost many a chase, and hours of time, and its starting to get to me.
Any help?
Tony.
Jan 2006 software (installed by Avolites)
Any help?
Tony.
