V9 show compatibility with other Versions
Posted: 12 Oct 2022, 02:21
by zahoorjury
Hi , in an upcoming project I am using a TT running v9 ( can’t upgrade due to old hardware) and another TT running V11 as a backup ( not in session) the main console will TT v9 , GOD forbid in case of V9 failure how can I run my show files on TT V11 ( v11 owner not agreeing to downgrade) , any ideas or any app to make show compatible between versions ? .
Re: V9 show compatibility with other Versions
Posted: 12 Oct 2022, 10:48
It should be fine. Shows are forwards compatible. Just make sure you have a full save (ie. not an autosave). Autosaves will only load in the version they are saved from. Potentially you could also test this in advance by taking your v9 show and loading into v11 PC suite running simulator. I appreciate you may be programming on site and will need to transfer the final version there but it might give you more peace-of-mind to try in advance.
Posted: 12 Oct 2022, 16:50
by zahoorjury
Thanks for advice, I will try it on PC as you said .
