Improvements fot timeline and other tips
Posted: 16 Dec 2020, 14:31
Thank you for this beta and the addition of the Timeline! It's really a great tool. It's not bad to use and easy to configure even without a tutorial.
The addition of the 3rd screen is also a great idea. I love it.
Some problems encountered
- When the TL is assigned to a PB or executor, the blue LED has a permanently low intensity. It would be interesting to have a higher intensity when it is active. As for a CUE.
- Since Saturday, I have been testing the v15 b90 and now b97. I was using a TL, everything was fine. Today I launch Titan, I play the TL... and display problem. The Timeline View window is there but track 1 is no longer visible. Titan asks me to create or select a TL. If it is played, when I launch Reaper, the fixtures react. I can provide my file if needed.
- If my PB is a Shape (Dimmer Saw, 1 cycle), I can play it in flash for the first time, the following times it is no longer react. If I play it with the linear cursor, no problem.
Improvements and wishes
- Timeline view is not in "Open Workspace Window". This is a pity. Maybe add it because you might look for it there naturally.
- At the SWOP level, two things:
-- Create a Timed SWOP on the same idea as Timed Flash ? I would like to have this function.
-- Add a Playback View option like "Ignore SWOP" and "Ignore Grand Master". It would be so handy sometimes. It would avoid messing around with priorities.
