Auto run playbacks on load
Posted: 14 Sep 2020, 16:35
by gazneale
Hi folks.
Is it possible to set playbacks to run on show load in titan v9? i have a setup at the moment using titan 11 on a titanone with some playbacks set to auto run on load, however the other setup is using a pearl expert running v9 and i've not yet found a way to do so if it is possible
Re: Auto run playbacks on load
Posted: 14 Sep 2020, 19:32
by TWC
Yes. In the playback options. You can choose if the playbacks runs on start-up or not. Just press he playback options softkey then select the playback, then softkey A 'playback'. It's in that menu. You also need to make sure startup playbacks are enabled in the user settings. Hold down avo and press disk, then choose user settings, in the general tab there is an on-off switch to set it.
Hope this helps.
Posted: 14 Sep 2020, 20:22
TWC wrote:Yes. In the playback options. You can choose if the playbacks runs on start-up or not. Just press he playback options softkey then select the playback, then softkey A 'playback'. It's in that menu. You also need to make sure startup playbacks are enabled in the user settings. Hold down avo and press disk, then choose user settings, in the general tab there is an on-off switch to set it.
The run playbacks on startup option was introduced in version 10.1 and therefore unfortunately is not available in version 9.
Posted: 14 Sep 2020, 22:55
by TWC
Omg yes. Sorry
You have to do it with a macro pre version 10.
Posted: 18 Sep 2020, 07:08
by icke_siegen
I fear the macro thingy doen's work either (it doesn't even work in the current version...).
Maybe triggering itself might work (with an LTP channel which defaults to 100%, and sACN trigger to the console itself) - but this needs to be tried.
