tiger touch problem
tiger touch problem
i can't use the middle wheel in the shape generator size, gobo, color, effects on tiger touch version 9 .... I don't know if it's a mistake but the center wheel doesn't work .... is it any configuration?
Re: tiger touch problem
It could be a loose connection, to check start by open USB Expert Console from the Tools > Control Panel menu. Firstly check that all panels are shown with a green icon in the top left and there are no errors reported in the bottom left. As you turn the wheel you should see the inputs appearing in the centre column, you can try turning other wheels or pressing buttons for comparison. If the inputs do not appear open up the console using the screws at the front and check the connection to the wheel, I believe that wheel should be connected to the playback fader panel.
