Move in dark
watty
Move in dark
Postby watty » 10 Sep 2019, 09:44
Hi all,
I would like to know the best and/or simplest way to create a moving head saw tilt where the light is on as it drops and off as it rises. I am thinking along the lines of a two step chase with move in dark on the rise but am not sure if this will work or is the best option?
Thanks in advance for any suggestions.
Re: Move in dark
Postby icke_siegen » 10 Sep 2019, 09:57
Provided you are running a reasonably current software version keyframe shapes are the way to go.
Create a kfs with only the dimmers on/off. Then add a layer with the movement. Now offset the layers to each other, change slopes etc. You'll have much fun as soon as you get the hang.
watty
Re: Move in dark
Postby watty » 11 Sep 2019, 20:04
Thank you for the advice - I have just about got to grips with KFS and it was easy to achieve the desired look.
