Palette Overlap
Michiel3000
Palette Overlap
Postby Michiel3000 » 18 Apr 2019, 10:53
Hi all,
Where is the fixture order of my palette overlap defined. I already tried to change the groups 'fixture order' and 'layout'. When I change color with palette overlap 0% the fixtures change from left to right, instead of from the middle to the out-points (which is what I want to do).
Where do I have to change this order?
Thanks in advance,
Michiel
sideshowbond
Re: Palette Overlap
Postby sideshowbond » 18 Apr 2019, 11:05
there is an option called 'Direction' in the pattern selection menu (All/Odd/Even)
Michiel3000
Re: Palette Overlap
Postby Michiel3000 » 18 Apr 2019, 11:17
Thanks a lot, that fixed it. Is there a way to 'save' it. When I clear my programmer/fixtures. The order is set back to none?
sideshowbond
Re: Palette Overlap
Postby sideshowbond » 18 Apr 2019, 11:19
press and hold clear and go into clear option. You can select if clear should clear the direction as well.
Michiel3000
Re: Palette Overlap
Postby Michiel3000 » 18 Apr 2019, 11:23
Off course, thanks a lot !!!
Bart K
Re: Palette Overlap
Postby Bart K » 18 Apr 2019, 20:35
What am I missing? (Working on a Avolites Arena/Tiger Touch 2)
- I select the 'odd/even/all' grey button
- Change the direction
- Changed the clear option. To not clear the Directions.
- Set my pallet overlap to 0%
But when I hit a colour from the ''colours'' window it only goes left to right.
From the middle to the out points doesn't work?
Do I need to make a ''ALL fixtures'' group with the right fixter order?
Thanks in advance!
sideshowbond
Re: Palette Overlap
Postby sideshowbond » 18 Apr 2019, 22:48
Interesting, works for me.
Select group, change direction, set master fade and overlap, apply palette. If the group has no edited order it'll just be ordered automatically (selection order) which will also be its generic layout (I'd change the layout rather than the fixture order in this case).
Site Admin
Re: Palette Overlap
Postby Gregory » 19 Apr 2019, 14:07
Please note that direction (in the All/Odd/Even menu) originally did not apply to palettes, what versions are you both using?
Michiel3000
Re: Palette Overlap
Postby Michiel3000 » 19 Apr 2019, 15:55
I tried some more things out and I'm still having the same problems (same as Bart K described). When I change direction, it works until I clear the fixtures. Even when I have direction excluded from the clear options. I'm using titan v11.1.
Re: Palette Overlap
Postby niclights » 19 Apr 2019, 16:07
I don't think this works in 11.1 but, all being well, should be possible in the next version.
Michiel3000
Re: Palette Overlap
Postby Michiel3000 » 19 Apr 2019, 16:33
So there's no other way to change the overlap order than doing it each time again after clearing?
Other question: what does the fixture order (the one you manually define for each group) specifically affect if it isn't affecting palletes?
Thanks!
Bart K
Re: Palette Overlap
Postby Bart K » 19 Apr 2019, 16:54
I'm also using Titan V11.1
When will Titan V12 will be released?
If you say it like this there will be some nice updates in the new version.
Re: Palette Overlap
Postby niclights » 19 Apr 2019, 17:05
Michiel3000 wrote:So there's no other way to change the overlap order than doing it each time again after clearing?
As far as I am aware direction is not used for live timed palette recalls. So it is not about clearing but about needing a fixture order (either manually from selection or from a group)
Michiel3000 wrote:Other question: what does the fixture order (the one you manually define for each group) specifically affect if it isn't affecting palletes?
It does affect live timed palette recalls with overlap. It is the direction that is not currently used.
Some other things off the top of my head:
- Fan
- Effects (ie. Shapes/Key Frame Shapes/'Pixel Mapper)
- Pattern selection
- Overlap in cues
Bart K wrote:When will Titan V12 will be released?
When it's ready? (standard answer)
Michiel3000
Re: Palette Overlap
Postby Michiel3000 » 19 Apr 2019, 17:32
Thanks for your answer, so if I understand it correctly I can use the group fixture order for pallette overlays, I have it layed out correctly, but how do I use it for my palette overlays? This was the way I originally wanted to make the effect
Maybe just some clarification: I want to make a few macros that change the direction. When I'm busking shows I can easily change direction, palette fixture overlap and palette fade to change between my (color) palettes.
Thanks!
sideshowbond
Re: Palette Overlap
Postby sideshowbond » 19 Apr 2019, 17:36
as for your macros: I already made them
https://www.avolites.de/wiki/macros:example:programmerdirection
Shame direction isn't working the way it is meant to be. I knew you can't save direction to cues but wasn't aware it didn't work properly for palettes either (I run all my shows off cuelists and playbacks...)
