Titan connecting to Capture Solo 2018
Posted: 24 Jan 2019, 16:35
I've bought Capture Solo 2018 and have some problems with the connection between Titan 11.1.26.5 and Capture. Following the Capture Live: Avolites Titan Special webcast (https://www.youtube.com/watch?v=hhA6SOd ... e=youtu.be) should be relatively simple. The dimmer patches syncronises between the tools. But DMX intensities does not work well.
When using one spesific PC for Titan and my own PC for Capture, the attached DMX Settings shows up. To reflect DMX from Titan in Capture, it is necessary to use Art-Net Node Capture(...):Universe 0. Running both tools in same PC, only Art-Net Node Broadcast: Universe 0 shows up. And using that node gives no DMX to Capture from Titan. Using a third PC for Titan gives the same result wit only Art-Net Node Broadcast: Universe 0 showing up.
All three PC's has the same Network spesification.
1) Why is the Art-Net DMX Node different from the spesific PC for the two other?
2) How to get the Capture Art-Net Nodes into DMX Settings for the oher PC's
Regards Eystein L.
Regards Eystein L.
