Tracking issue - scrollers and LED fixtures
Posted: 06 Nov 2018, 19:44
by ehal_no
Under programming sessions we have some problems with scrollers (Xpress19)and sometimes LED ETC (Color Source). We are using tracking. After changing color in cue n, and going back to cue n-1 after Clear, the colors does not go back to the tracked values in cue n-1.
Is this a bug or do we have to go back to colors in cue n-1 manually?
Re: Tracking issue - scrollers and LED fixtures
Posted: 07 Nov 2018, 06:19
by sideshowbond
What happens if you fire the cuelist a second time or respectively go back.even further to n-y where the last colour change before the one in cue n. Also changing the behaviour of your clear button (to "release to playback values") might help.
I can only guess here but I assume the colour values in cue n-1 are tracked and not hard values. Hence Titan might stick to the last value even if cleared as LTP is LTP on Avo (at least by default) and if you run a cue that doesn't really have any colour info it'll stay on the last value. Changing you clear behaviour Titan should revert to tracked colour info.
