Cue Lists - Shapes, Tracking & Copying Cues
Posted: 26 Mar 2018, 23:50
Hi
I need some help please, I have been called into a job to help plot a theatre show due to crew sickness. They are using a Titan mobile running V10 and a Cue List which has about 30 cues in already.
Unfortunately my knowledge of cue lists isn't great, I have used them before and never got on very well with them mostly because of understanding and getting the tracking correct, also only used generics in the cue lists before not heads.
I'm having the following problems
Shapes & Tracking
I have a cue with 2 shapes running but they are tracking into the following cue and don't want them running in that following cue. I have tried using include on the following cue, removing the shapes and re recording the cue by replacing it but the shapes are still there and run in the second cue?
Is there a way in playback view to edit the cue and remove the shapes in the second cue or stop them from recording into the next cue, is this using block shapes?
If yes how do i get the switch to display in the view shapes column as i just have the name of the shapes in both the cues and no switch to block in the second cue?
Copying cues
When recording a theatre show on say a strand desk, I'm used to everything recording in a cue each time you record a new cue. If i want to repeat the cue later I recall it and record as the new cue and everything is programmed into the new cue
On the Mobile a look is built up of adding cues, say 4 cues, so whats the best way to copy the whole look to repeat it? If i run cue 4 and then record it at as cue 10 it only has what I added in cue 4 not the whole look? I.e. i want the whole look to repeat for cue 10.
I have watched most of the 2 webinars in cue lists so have a better idea but help with the above would be appreciated as i start plotting again at 8.30am tomorrow morning.
Many thanks
Shapes & Tracking
Copying cues
Many thanks
