				DJtap
				Posted: 07 Mar 2018, 07:51
				by kani
				Hi
I have a question about DJtap.
Does DJTAP work with TC Supply's software and network connection?
Please let me know if anyone used this function.
Best regards,
				Re: DJtap
				Posted: 07 Mar 2018, 09:07
				by Gregory
				The DJ Tap feature was designed and written to work with their software using their network protocol. This was done for the
Jewel nightclub prior to their official release.
				Re: DJtap
				Posted: 08 Mar 2018, 00:38
				by kani
				Hi Gregory,
Thank you for answering.
There is no description in this manual about this function.
Do you know how to connect?
What should I set in the console?
Please tell me if you understand.
Best regards,
Kani
				Re: DJtap
				Posted: 09 Mar 2018, 08:14
				by Gregory
				Assuming both console and computer running TC Supply are on the same network, with compatible IP address, they should connect automatically. Within Titan you can enable or disable the function by going to System > Triggers by toggling the  trigger mapping on or off. As you can see in the mapping the master level will control BPM Master 1 and therefore any playbacks set to use that as their Speed Source in Playback Options.
				Re: DJtap
				Posted: 12 Mar 2018, 09:29
				by kani
				Hi Gregory,
Thank you.
I tried the ShowKontrole software.
I tried IP to 2.X.X.X on the same network.
I turned on DJ TAP of Trigger.
But it will not be connected.
When connecting to ShowKontrole, does Console appear as a device in TCNet?
Now I am testing it with not knowing anything.
I would appreciate any advice.
Best regards,
Kani
				Re: DJtap
				Posted: 12 Mar 2018, 14:11
				by Menno.Appelhof
				I have briefly played around with it in our showroom, but as I do not have a MAC to try it again I eed to try and recall what we did.
We created a simple network setup on the Art-Net rage
Turned on the DJ Tap Trigger and connected several clocks, only to find out that we got it working on Master BPM Master 1 clock.
That one we connected to a chase and after relaunching the playbacks it worked.
I believe we could see the Arena on TCNet but I am not sure.
Sorry I can not be of more help.
				Re: DJtap
				Posted: 22 Mar 2018, 01:23
				by kani
				Hi
Thank you for reply.
I tested the combination of ShowKontrol software and CDJ. I could not connect to the network. I changed IP, but it was useless.
It is a question.
1. This time, I was testing with Titan Ver 10.1 and ShowKontrol V 18.3.6. Is there any problem with this version combination?
    Also, can you tell me the version you are using in the showroom?
2. If it is connected to ShowKontrol and you can synchronize BMP, will the value of BPM master in Console change?
    Or will BPM master values not be changed, will you sync?
I would like to see if there is a movie when connected.
Best regards,
Kani
				Re: DJtap
				Posted: 23 Mar 2018, 09:43
				by Menno.Appelhof
				Hi Kani,
This week I talked to another user that also has a problem with this connection.
I believe it was version 10.1, but you can try 10.0. I have no recollection about the version Titan or ShowKontrol so I can not answer that question.
If it is connected to ShowKontrol the BPM on the BPM Master in the console will change in realtime.
If I had access to a Macbook (or mac in General) I could make a video, maybe a video would be already available at Avolites, but Gregory would know about that.
				Re: DJtap
				Posted: 23 Mar 2018, 13:12
				by kani
				Hi
Thank you for your sincere support.
I am waiting for more information.
Best regards,
Kani
				Re: DJtap
				Posted: 03 Apr 2018, 01:51
				by kani
				Hi
Are there new advice on DJTAP functions?
I want information quickly on this issue.
Best regards,
Kani
				Re: DJtap
				Posted: 30 Jul 2018, 19:46
				by Robertvanspijk
I would also like to know if there is more info available on this.
I'm running 10.1, have tried it on numerous desks, no luck!
Thanks in advance!
Robert
				Re: DJtap
				Posted: 01 Aug 2018, 01:45
				by kani
After this, there is not any information from Avolites.
Nothing is written in Relese Note of V11.
Best regards,
				Re: DJtap
				Posted: 01 Aug 2018, 09:35
				There was nothing written about this in the v11.0 release notes because nothing relating to this was changed in that version.  However, I will admit the information in the v10.1 release notes where this feature was introduced was limited.  Unfortunately I can't add anything further but hopefully someone else can help.
				Re: DJtap
				Posted: 01 Aug 2018, 09:49
				by Robertvanspijk
				I’ve spoken with TC Supply, (Showkontrol).
They are going to have look at it at their office.
If I hear somethig new, I’ll let you guys know.
				Re: DJtap
				Posted: 02 Aug 2018, 01:38
				by kani
				Hi
I also want to know so please let me know if there is new information.
Beat regards,
Kani
