Faders in Tiger Touch Simulator
Apologies if I'm missing something in the manual or on another post but I can't for the life of me find a way to trigger a fader in tiger touch simulator. Trying to build remote triggers and can't move the fader to select that as a hardware trigger.
Re: Faders in Tiger Touch Simulator
I tried it and it works for me: when creating a trigger, at the stage where it says 'Press or move a fader or one or more buttons to trigger', if I now move a fader in the virtual panel, it correctly detects this and stores the trigger.
However, the faders in the virtual panel wiil not move, only the result will be as like as the faders were set to some values. That's not a bug, and has never been intented (I believe so at least). Can you explain the steps you are doing to reproduce the problem?
Best, Sebastian
Best, Sebastian
So when I get to the stage to select hardware, I move the fader on the virtual panel but nothing in the software responds to the changes on the virtual panel.
