Edit Shapes
Posted: 09 Feb 2018, 20:40
Can someone help me on this one - I'm not sure if I am missing something or if there is a problem with 10.1 re editing shapes saved in the shapes palette window.
I set up a phased circle for a group of fixtures and saved it as a shared palette in the shapes palette window. All works fine - select fixtures, locate and hit stored button and shape runs on fixtures.
If I try and edit the saved shape, and update it, it no longer runs. If I re-create the shape and try and save it to the palette button, by replace or merge there is a message that says "cant replace" (or very similar)
My concern is that if I use a shape palette in a batch of playbacks and then can't edit it, my only option would be to delete it which would then mean editing all the cues individually.
I also noticed that when I viewed the shape in palette view, there was sometimes more than one version showing with an original and modified version showing. I'm not sure what is happening but after reading the manual and trying as many things as I could think of, I just can't get it to work.
