Playback Master / Group Master vs. Dim Chase
Posted: 12 Sep 2017, 21:11
Hello everyone
Hope your doing well out there...
I Hope im in the Right Area of the Forum... Sry if not, just move me to the right spot.
My Issue:
Scenario 1:
I Programm a "Normal" Playback Master (Dimmer 100% Record to Fader (Fade Mode 2)) this works fine, until i run a Dim effect. If the fader is on 0 the effect still shows up.
To fix this i tried to Create a Group Master (Scale Master)
Scenario 2:
I Programm a Group Master (Copy the Fixtures to a Fader). The Fader is on 0% the dimmer is 0%. If the Fader is on 100% the Dimmer stays on 0%! if I run the Dim effect, it only shows up when the fader is on 100% (one Problem solved
So i ended up to program a Playback witch includes all Fixtures Set to 100% Dimmer. This Playback must be activated the whole time so i can use the Group Master as a actual "Main Master/Dimmer Master"
that leads to my question:
Is the workaround with the "100% playback" the only possibility to crate a Master like i described. Or are there other possibilities to crate a master wich also blocks dimmer effects?
And how are you guys handling the whole master Thing? Some Workflow reports would be nice
Thxs for all the Answer and help
My Issue:
Scenario 1:
Scenario 2:
