Hello community,
I have built a cuelist with a cue which I copied many times in that list, but on some places I don't need a playback that is stored in it. Is there a way to off it or release it?
Thanks and best regards,
Peri_95
Releasing playback from existing cue in Cuelist
Re: Releasing playback from existing cue in Cuelist
I think more information about the cuelist and what you are trying to achieve might be needed but (assuming it's tracking) one option might be to insert a cue with tracking set to 'Solo'. Values from previous cues will track into subsequent cues but will not track into the solo cue.
Hello niclights,
Yes. I need more information. I am a beginner but I understood you. I don't think that you understood me though. I'll explain it better.
In one cue I have blue washlights on the stage and the playback is loaded into the cue so it has additional RED colour spreading(final light would be blue to magenta spreading).
I wanted to use that same cue but without that spreading. So, to have just blue washlights on the stage.
I know, I can easily program blue washes from scratch but I needed many times a function to release a playback or delete it from the cue.
Is there a way to do that?
Best regards,
Peri_95
Best regards,
Peri_95
I got it. I have to click "view cue" and delete running playback.
Thank you anyways,
Peri_95
Thank you anyways,
Peri_95
